Hi,
I have a 1" threadless steerer and an 1 1/8" stem. With the shim in position and the stem pinch bolts tightened I have no 'gap' between the faces. The pinch bolts bring the faces together rather than leaving a 2-3mm gap!!!!!!!
The stem is clamped but I am a little concerned as to how safe it is!!!
Why are the faces be touching, can you buy 'thicker' shims.
Cheers
CRAIG
Cheers
CRAIG
