Last night I had the displeasure of my bike being stolen.
It was locked with a Magnum lock and Kryptonite cable through the frame and both wheels. Well lit main road near Shoreditch Station.
This is the bike as new, but now also has white mudguards attached.
These are all the distinguishing features I can think of:
- The front 4 screws securing the stem are all rusty.
- One of the tyre valves is longer than the other, with a red cap. The shorter has a black cap.
- The front dérailleur is missing a cap to the cable, which is frayed. To my knowledge, all other cable endings are capped with a silver piece.
- The pedals are an spd combo; black plastic surround with spd cleat fitting.
- Underneath all fixings for the mudguards, I applied an adhesive rubber to prevent marking. One of the rear pieces was folded on application.
- The left-hand dropbar has a few rips in the bar tape toward the end.
- The left-hand brake lever has a roughly triangular cap on the top which is no longer properly affixed and therefore can be easily pulled off.
- The bottom of both gear shifts and brake levers are scratched from a fall.
- The rear reflector is positioned high, directly underneath the saddle.
