strava segment times
sanddancer
N/Wales
Hi, I am thinking of commuting and was wondering if there is a way of looking at a route I have done on strava that passes my work and checking the time taken to get there ?
Thanks for any help and apologies for the numpty question :biggrin:
potsy
Rambler
My Armchair
You could create a segment of the route, make it private if you don't want others to see it :okay:
potsy
Rambler
My Armchair
No need to pay, assuming you have recorded a ride that includes your commute route then simply go to that ride, click on the 'spanner' symbol and create segment option is there.
Leaving a bit early is always a good idea for the commute though :okay:
You can also (assuming you are on a computer, not a tablet) hover your mouse over the graph of the ride underneath the map. A blue dot on the map will show you your position that matches the point on the graph, and the graph will show the elapsed time at that point - ie the time including stops.
sanddancer
sanddancer
N/Wales
Thanks potsy and jef.
I was on the app, I logged in via the web on my phone and used the spanner icon to create a segment. That option doesn't seem to exist on the app.
ps potsy. I meant leaving even earlier than early lol. I guessed right at 35 minutes though so will leave an hour before shift starts ;)
Thanks fellas ;)
gaz
Cycle Camera TV
South Croydon
If you click and hold from that point you can then drag it to another point and get more detailed info ;)
