Andy in Germany
- Rottenburg am Neckar
Having managed to change my cassette and chain without breaking any more tools, I've hit a new problem. My front mech won't move the chain from the big ring to the middle ring. Changing the tension in the cable got it working, but then it rattled when I was using the middle ring and went to the smallest gear on the cassette.
What is especially annoying is that it worked fine yesterday morning on the way to work, but on the way back it just rattled when I tried to change down.
The mech hasn't been moved and worked fine before. I adjusted the limiter screw as it was throwing the chain when I changed to the big ring, but the only real difference -apart from a new chain- was from a 7 to 8 speed cassette, but I can't see how that makes a difference as there was a spacer on the 7 speed so the small gear would be in roughly the same place relative to the big ring.
I may as well blame the weather as it was cool on the way in and hot on the way back...
