Stupid is as stupid does
Bristolian
Bristol, UK
Following my debacle on Monday, reported elsewhere, Tuesday dawned and I set about replacing the rear gear cable. Maybe I should have stayed in bed :wacko:
First off, maybe the reason I didn't have a rear gear cable in my saddle bag was because I didn't have one so off to the LBS to get a new inner cable. Back in the garage I cut a new outer cable sheath and then feed the new inner cable through the brifter. This is where the stupidity comes in because I hadn't realised that despite the mechanism wasn't fully in the correct gear so the cable nipple went where it shouldn't have gone ... and despite partially disassembling the mechanism to gain access I couldn't get it back out. Having wasted a couple of hours trying and failing I unwrapped the bar tape, removed the brifter and toddled back off to the LBS to see if they could help.
Thankfully, the young mechanic at the shop wasn't busy and within about ten minutes the cable was back out again ... phew :bravo: He also found a length of broken cable inside the mechanism, which he thought was probably why the mechanism wasn't in the right place before, and he thought one of the return springs felt a bit weak. He also jokingly pointed out I should have looked more carefully - can't argue with that :whistle: Back to the garage again, brifter back on the bars and ready for round two. This time everything goes smoothly and in no time I've got gears again; nicely indexed and all tickety-boo ... well nearly. A quick ride up the road working through the gears and I'm in bottom gear (largest sprocket) and all is well until I push the lever to start going back towards a higher gear there's no resistance, no reassuring click, nothing, nada :eek: So, I pull into the kerb and see part of the return mechanism is sticking out to the side of the brifter so I push it back in and hey presto normal service is returned.
For now I can make the shifter work by pressing the arm back in with my finger but it's only going to be temporary. The decision I have to make is try to get this shifter repaired or buy a new/used one? The LBS are going to look into a repair but they don't know if the parts are available any more.
Happy days ^_^
raleighnut
Happy days ^_^
And people wonder why we like downtube shifters
Road STI - got my first ones a couple of years ago. Work great, but it has to be Shimano SP41 cables for 10 speed or more. Similar with SRAM MTB 10 speed - needs to be the high level Jagwire cables. Normal PTFE coated outers and stainless inners work so well for a while, not as long as SP41 though. Any sign of dodgy shifting, you need to change cables.
Punkawallah
I’m sure there is a set of bar-end shifters at the shop if you are thinking of up-grading? ;-)
Seriously, they deal solely in second-hand bikes, and if you give me the model of brifter I can have a look for you.
PaulSB
Happy days ^_^
This is why I pay my LBS to do all servicing on my bikes.
Alex321
South Wales
My right hand brifter has been doing that for over a year. Usually happens the first time I try to change to a higher gear on any ride, and occasionally after that.
As you say, just push the sticking out bit in with your thumb, and it works.
It would be more of an issue if it caused problems when downshifting.
