buddha
For Sale: Surly 1x1 Rigid Disc/Canti Fork ...
Ideal for MTB conversion, similar fork to Kona Project2. See here for Manufacturer's page, and here for Wiggle reviews.
Spec:
Rake: 45mm
Steerer: 1 1/8" threadless cut to 167mm
80mm VERSION (ideally replacement for 80mm sus forks):
Axle-To-Crown: 413mm
ISO mount disc tabs,
Removable Canti bosses
Weight, disc: 1.1 kg (2.34 lbs)
It has been used, but only indoors on a turbo. There are some marks where it has been clamped to the turbo front-wheel stand (see below), but these are only cosmetic and can be easily touched-up - which I can do if you want. Colour is gloss black.
The steerer has been cut to 167mm. So please check that this is enough for you. Star Nut is included and in place.
As it's 1.1kg delivery will be £5.94 (1st class recorded).
These sell for £62.99, so I'll ask for £35 inc delivery.
Thanks, Peter
Spec:
Rake: 45mm
Thanks, Peter
