The new girl
s7ephanie
middle of nowhere in France
went out on the new girl today for a couple of hours, now thing is although i had saddle height same as old bike, toes just touching ground when on saddle, i found that my knees hurt and it felt like legs didn't strighten out on pedels like old bike, could it be a shorter crank arm length ? the wheels are 700c against the old 26 and are skinnier, bike felt lighter and a little more responsive, couldn't tell if it was faster as i didn't have the counter thingy set up
i have put saddle up a bit for tomorrow
but i like the new bike and she is called Lil because she is silver with lilac trim, so called lilac Lil just means i need new clobber so i don't clash :highfive:
stephec
Bolton
Measure from the top of the saddle to the centre of the pedal axle on your old bike, making sure the seat tube and crank form a straight line, then transfer this measurement to your new bike.
Pale Rider
Makes sense, with you on the saddle, the ground is about an inch further away than on the old bike due to the bigger wheels.
Setting the saddle for tip toe on the new bike will give you slightly less extension to the pedals, which is what you have found.
Moving the saddle up a bit, as you have done, is the solution.
vernon
Harder than Ronnie Pickering
Meanwood, Leeds
I could be worse @Pat "5mph" and @s7ephanie ...
You'll need some stiletto toed shoes to touch the ground on this:...
alans
black belt lounge lizard
Staffordshire
How on earth do you get on or, even worse, off that when you stop?
Carefully I expect
welsh dragon
Is there a way of learning how to fall off elegantly? Or do you just end up in a heap on the ground after attempting to dismount that contraption?
screenman
Distance from pedal to top of saddle is more important than saddle to floor, there is setback to think about as well.
Take vertical line up from the bottom bracket then measure from that to the saddle.
