[QUOTE 2559168, member: 9609"]I wasn't even remotely surprised it was using more electric, but was surprised it may have been accounting for a fifth of our electric use.[/quote]
It is a lot of electricity, granted, but a fridge is also a heater if you look at it from the back.
[QUOTE 2559168, member: 9609"]I wonder how much energy has been wasted though; in its cooling process it generated a fair amount of heat, for may be 11 months of the year that heat energy would have supplemented our central heating. And with a good percentage of electric coming from renewables (wind hydro and nuclear) may be my reduced carbon fuel burning could be argued to have been a good thing.[/quote]
It is low grade heat, a bit like ground source heating.
Back in 2002 I suggested, at The Centre for Alternative Technology, that maybe one day we should be recovering the heat from the back of the fridge to heat water alongside a solar hot water system. It would make the fridge a little more efficient by cooling the radiator at the back of the fridge while raising the water temp a little that goes in the solar set up.
The objection was that it would be better to add 100mm of insulation around the fridge to reduce the loss of 'coolth*'.
I still think it is worth an experiment to see how much heat comes out of the back of the fridge.
*Coolth is a Mike Thompson invented term to describe the opposite of warmth to make analogies easier to understand.
