Ticking metallic sound
DJ106
Hi, I'm getting a ticking metallic sound which is not related to pedalling as I also get it when coasting. I cannot pinpoint the origin. I know it's difficult to 'diagnose' from video but any ideas or suggestions are more than welcome. Video link below.
Thanks
Video link
Paulus
Barnet,
Could be any number of things.
Hold the front brake on and rock the bike back and forth, any ticking?
lift the front wheel off the ground and rotate any ticking? Turn the handlebars left and right, any ticks or creaks from the headset?
Do the same with the rear wheel.
Could it be the seat post creaking , remove, clean regrease and refit.
Check the spokes to see if any are broken and clicking on the fork or frame.
You say it doesn't happen when pedaling so it can't be the BB or drive chain, or even the pedals.
It can take a while to eliminate strange noises.
roubaixtuesday
self serving virtue signaller
^^^^^ this.
Further suggestions:
see if it happens in or out of the saddle to eliminate seatpost.
Try putting all your weight on front or rear wheel to isolate possibilities.
Wheels can make ticking noises, both from spokes moving over one another at crossover and friction at the rim. A drop of lube at all the eyelets and crossovers can solve it. If you have an alternative wheel to swap in, that's a good way to eliminate.
DJ106
DJ106
Hi, Thanks for all your replies. I have gone through most of them already and at one point I thought I solved it when I found a very loose spoke. But it came back. I'll lube all the spokes next. To be honest it seems to be coming from the frame itself but I'm not sure how to actually check it.
All uphill
Still rolling along
Somerset
I've just replaced the headset on one of my bikes to solve an irregular ticking. It only stopped when I took my hands off the bars.
I haven't had that one before.
I've had ticking saddles, shoelaces against cranks, mudguards against debris on tyres, saddlebag, spokes, amongst others.
Manglier
Regular
Rotherham
I don't know the set up of your bike but, for what it's worth, I had an insistent ticking on mine. I eventually traced it to the Jagwire Elite (same for Nokon), compressionless gear and brake cable housing. Many scrupulous washings and no special lubrication resulted in the infuriating ticking noise. Liberal application of good ole' GT85 on a rag was my friend in the end.
