golty
Regular
Hi
I have just got a new Boardman TT bike and I'm having issues with the front brake (TRP mini V brake)..
It was working fine until I messed with the bolts in an attempt to adjust them for deep section wheels. There is no feel at all in the brake lever and the brakes do not spring back when the lever is pressed, so basically they don't work..
I'm not good with bike mechanics but can anyone explain what I need to do, I've put some pics below of the brakes and the bolts I can see that could be adjusted, there is also a barrel adjuster..
Back bolts
Side bolts
Can anyone attempt to explain what I need to do to fix the brakes, or should I just take it to my LBS?
Cheers
Back bolts
Side bolts
Cheers
