SavageHoutkop
- South Manchester-ish
In the spirit of 'new thread' day; here's a dumb question I've been pondering for a while.
I started commuting in June; I've never cycled in snow/ice, and have recently had experience with leaves
(well, the first time I slipped it was cornering too fast, the next time I think it was trying to mount a kerb side-on because I misjudged the start of the footpath (shared use before anyone jumps on me!) as it was hidden underneath the leaves).
Following on from the other 'leaves' post it seems that leaves are, possibly, more difficult to ride on than ice. Can anyone confirm/deny?
Then I started thinking, well, if you're after more grip, usually the tyre pressure is decreased (mountain biking vs biking; rallying offroad vs onroad). However, it's usually due to mud or non-'hard' surfaces being ridden on rather than just a grip improvement (although, if tyre pressures are low, it's harder to pedal, presumably because of 'better grip'?).
So, is there an argument to say that it's better to run slightly lower tyre pressures in winter to give better grip on ice/leaves - or are you just doomed if you hit a patch, tyre pressure irrelevant?
If it helps, I cycle a Brompton so have little wheels, and high pressure.
