Tyre Vs rim sizing
dhd.evans1
I've acquired a singlespeed steed again, this time with rim brakes instead of disc. It was armed with WTB Thick Slick 25mm tyres but I'm not much keen on them.
Working at a bike project has advantages as we have plenty of tyres (mostly recycled) kicking about. Also, this thing has plenty of clearance to go up from 25mm.
I tried a couple of 32mm Gatorskins on but they kept 'bulging' the tyre at the valve. Tubes are still 25mm for info. The rims say "700x14". I've got a 28mm Gatorskin to sit fine on the rear.
First question, why are the tyres bulging? is it related to rim size? Secondly, do I need to get rims with a larger width to fit the larger tyres?
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Yes, 14mm is below min recommended internal rim width for 28mm tyres. Of course it may just be you did not push valve up when fitting tyre.
Paulus
Barnet,
I would make sure the tube is pushed up into the tyre before inflating, also make sure the tyre is seated correctly.
The rim may be a little small for a 32mm tyre, but with a little care it should fit on.
