Ultegra triple to double shifter
boydj
Paisley
I think you need a double shifter, sadly.
No reason why that should be the case. Once the limit screws are set, the shifter should work fine. I have done the same with a Campag shifter and it works fine.
accountantpete
Brexiteer
The main element in chainring spacing is the speed of the group - so a 10 speed triple will be good for 10 speed double.
I think Shimano advise that you set it up as the granny ring setting becomes the 39t and therefore the middle ring becomes 53t.
You then limit the movement leaving the third shift unused.
