UPDATE. What can be causing the light to flicker ?
Dave7
Cheshire
We have 2 double wall lights.
The bulbs are screw in type.
Just one light ie one bulb has started to flicker.
Its not all the time....... it can be ok for hours then starts for maybe 10-20 minutes.
I have unscrewed the bulb and made sure its seated properly.
Any ideas ?
sleuthey
From what you have said it’s clearly not your household wiring or switch. My money would be on you having cheap led bulbs in the light and flickering being part and parcel of having them (ours do this and BIL electrician says this is the cause).
swap the flickering bulb with the adjacent one and if the same bulb flickers then this is the cause.
In storm arwen our lights flickered a lot. If its windy and you've got overhead power supply (no longer allowed) it could be affecting power supply enough to only show up in your lighting.
newts
Isca Dumnoniorum
Swap the bulbs over and see which side flickers
Daffodils or snowdrops?
Dave7
Dave7
Cheshire
So obvious I hadn't thought of it :wacko:
Strangely it's not happened since I posted.
The power of CC maybe ?
