Victorian oil lamps? Anyone?
swee'pea99
Just on the off-chance, wondered if there might be anyone hereabouts who could tell me what this little lever is for:
It seems to raise...
and lower
metal 'sleeves' around the wicks.
But I can't figure out what purpose that's actually supposed to serve.
I've been googling, but all I can get is endless links to lamps for sale, or people (mostly in America) talking about lamps that are similar but not the same, and, crucially, don't seem to have this 'sleeve' mechanism.
CC has helped me with many out of left field queries in the past, so I figured what have I got to lose.
Any thoughts appreciated.
Hugh Manatee
mmmm, sorry didn't look at the pictures properly. Some guesses:
A built in snuffing mechanism?
Something to stop it smoking when the flame is out but before it cools?
classic33
Leg End Member
If the sleeves fully enclose the wicks then you'd be cutting of one side of the "Fire Triangle".
Does the glass raise with a similar lever?
swee'pea99
swee'pea99
"a Victorian dimmer switch" - love it! When I get it going I'll check that theory. Makes sense. Certainly you get a bigger flame by exposing more wick (it has two windy-wheels on the other side for doing that).
Lozz360
Oxfordshire
I think it pushes the wick up. Most of them had a wheel that you turned so you could raise or lower the wick. I guess the lever only pushes the wick upwards.
sight-pin
I think the main lever is a snuffer and the two winding controls the other side will have push the material wick through the blades to be able to adjust the two flame height independently and to prevent smoking.
