Good.Bit of a bargain that. Basic but serviceable.
Shimano AlivioWhat a brilliant piece of business for 70 bucks.
And it comes with a pretty decent Suntour fork too(the start of the better ones)
What is the gears ?
How much would a bike shop charge for a fork service.Shimano Alivio
With 27 Gears.
The only problem with the bike is that apparently the lock out part of the fork is faulty and doesn't fully lock the fork.
Shimano Alivio
With 27 Gears.
True.Is it the pop loc on the handlebars that is the problem ?
Could be easy for a bike shop to repair,or cheap to buy a new one.
For 70 quid,it wouldn't bust your bank to spend a little more
Yes,it should good for a wee blast round most woodland trails.True.
Is the bike a good bike for the money then ??
Yeah I found that hilarious.Good buy
Matches the kitchen too
Have fun![]()
Thanks,The Hoodoo gets good reviews so you've picked up a good bike. It looks from the picture that it's not had too much tlc so things to look out for which may add to the cost are chain and cassette wear, tyre wear and maybe needing to replace gear cables and brake pads. None of those parts will break the bank and youtube is your friend if you need to learn how to replace any of those things. A fork service will cost between 30 and 60 quid, again, if you want to do it yourself, youtube. You may not need to do any of that but if you do, you have a bike worth doing it too.
