Wallpapering a small chimney breast
figbat
Slippery scientist
My daughter's bedroom has a narrow chimney breast running through it, from the fire in the room below. We are redecorating it for her at the moment and most of the walls will be painted, but she wants this chimney breast papered as a feature. I've never wallpapered before but thought this might be relative easy to do. However I have one concern - the paper she wants is 52cm wide. The chimney breast is 51.5 cm wide. By my reckoning it won't be easy to put a single sheet on the front face as there will be around 2.5mm of overhang either side, with the likelihood of the whole thing not being square anyway. It feels to me that such a small overlap will be difficult to fold over and will, in time, be a source of future peeling away.
The other option is to have a join in the middle of the front face, meaning papering around the external corner.
Any wallpaper masters here?
MontyVeda
2nd option, for all the reasons described in the first option.
If you make sure you match the pattern you won't see the join in the middle. And draw a vertical line in pencil to work to, either with a plumb line or spirit level to ensure the first sheet goes on straight.
It seems like you know what you're doing, despite not papered before. :okay:
edit... I'm guessing you'll have a full roll for a small section, so you can safely get it wrong several times before perfection is achieved.
Cycleops
Accra, Ghana
Joining in the middle might be problematic as the corners might not be vertical so when you come to folding the sides around the corner they won't lay flat. I'd go with a single piece on the front, if you're worried about peeling secure them with PVA. Then do the sides.
PeteXXX
Photo Winner
Hamtun
One roll will do 3 drops with a long pattern match, and 4 drops with small, or no pattern match. You'll have at least one full drop to spare if you join in the middle, then wrap around the edge, as @roadrash says.
Deleted member 26715
It will all depend on the pattern on the paper, but I would stay away from having joins on the bends
Widen the chimney breast by 5mm.
I've done that before it means you can get nice sharp corners, but it was 50mmish to get it true, I presume it's a rental or the best thing is to take the chimney out.
figbat
figbat
Slippery scientist
Thanks all. To pick a few points out:
- the rolls are 10.5m - the pattern is 53cm, so quite large
- the house is mine and the fireplace is used, so the chimney has to stay
- doing the whole wall is an option but this paper (that is the only paper in the whole world that must absolutely be used) is £50+/roll
I just know that doing it with a joint in the middle will leave a tiny strip one side or t'other - that's just the way things work out for me! The paper also demands "paste the wall" which looks like a perfectly reasonable thing to do, unless advice suggests otherwise?
Putting feature paper on a chimney breast makes a room feel smaller because you are more aware of the chimney breast intruding into the room. Better to have the feature either side in the recesses. It draws the eye beyond the chimney especially if it's a small room. Makes no difference to the actual space of course.
