Wanted: Chainset
just jim
I have this fixed/single speed project on the go and I a chain set to convert. Anything going? Crank arms only would be fine - 170mm...
How much were you looking to spend? I have one exotic option, and several less so.
just jim
just jim
Hmmm - like the Exage - that would do the job. Don't know much about this BCD stuff - if I want to swap chainrings around what do I go for?
They would be 110BCD 5arm. Same as a compact double.
I could chuck in a reasonable but not SS specific chainring with it, but you'll need to find bolts.
Paul_Smith SRCC
www.plsmith.co.uk
Surrey UK
This may help 'PCD' = 'Pitch Circle Diameter', some recognise this as also being called 'BCD', Bolt Circle Diameter, to help clarify what size you need we have also listed the bolt spacing, as this is easier to measure; being the distance from centre to centre of adjacent bolt holes and it is indeed why we have made a diagram to clarify
Paul_Smith
www.corridori.co.uk
Rhythm Thief
Ross on Wye
If you're still stuck for any reason, I have about four spare chainsets and some rings. I'll chuck in a pair of SPD pedals too, if you like.
Gooseboy
Kent
Chainset
Chris667,
if you dont sell the exage , i will have it
I am building a singlespeed at the mo and need a chainset
Thanks
PpPete
Chandler's Ford
Right hand crank 5 arm triple 130/74 mm, Sq. taper
Like a complete idiot I managed to strip the thread on the right hand crank of a perfectly good chainset. And therefore ruined the "spider" completely in removing it.
So I'm hoping someone has a spare kicking around. 170 mm long. Black preferred.
(or other length/colour if your have the left hand one too)
Alternatively if any one wants
black Shimano left hand crank,
52/42/32 black rings with plenty of life left,
all the chain ring bolts for above.
..... please PM me
Rhythm Thief
Ross on Wye
..... please PM me
You have PM
