wheeliebin
- The rolling hills of Hertfordshire
I know it's cold...when my rear changer jams solid.
On my commute this morning I found I could change to a lower ratio, but trying to go back up again the gear cable just goes slack and the mech doesn't move. I got off the bike a few times and tried to waggle things around but I couldn't get it to shift into a higher gear. On any slight downhill I just had to spin as fast as I could and then coast. After a few goes at freeing it, the changer then jammed in one position, wouldn't change up or down. I could have broken something whilst fumbling in the dark.
It's jammed before, always when it's freezing cold. I assumed it was a bit of moisture that had got in and frozen as I have always managed to free it off before, but not this morning. The mech is fairly clean and well lubed but the amount of crap I pick up from the roads means there could be some muck in there. The spring inside the changer seems to be intact.
I can move the changer backwards and forwards by hand, but not sideways. The cable seems to be free where it comes out of the housing into the clamp.
If it makes any difference it's a Deore mech.
Any ideas welcome!
Any ideas welcome!
