What sander for home use?
Glasgow
Hi all!
I'm looking to buy a sander.
I need to sand 10 door frames (not the doors, I'm getting new ones) and 3 rooms worth of skirting.
I'm going to repaint, no need to strip the wood bare.
I would like a tool with an efficient dust extractor.
Speed is not an issue, as I'll be working slowly when the gardening season is over, doing the rooms one by one.
Longevity of the tool is also not an issue, because I won't use it after this project.
Cordless is not essential, although I already have 4 X 2.5A batteries for the Bosh 18V system.
Not too heavy and easy to handle is essential, my hands are not very strong.
The availability of reasonable priced sandpaper suitable for the machine is essential, I'll be using loads!
What would you recommend, please?
I've got the Titan detail sander from Screwfix which is a belter for the money but the dust extraction bag is rubbish. You can get the pads really cheaply off Amazon. I got about 50 or 60 for I think £5 or £6. You want the detail sander not the Oribital Sander. I've got both and the Oribital sander is more for sanding down a whole wall etc.
classic33
Leg End Member
Run the hose from your vacuum cleaner to the area you're sanding. It'll pick up more dust than it would attached to the sander.
Glasgow
I tend to use a mouse sander. Some you can attach a hoover to them but you'll need one that copes with the fine dust.
Fossy, how do you do that? Does the hoover need to be on at the same time as the sander?
Should I watch a few YouTube videos? ^_^
If you're doing a skirting board then I think the detail sander is more appropriate as its smaller.
Thank you, that's what I figured.
I have seen a sander with interchangeable plates, one rectangular like @classic33 linked to, the other is mouse shaped.
Glasgow
Basically, hoovering after me is the more efficient way?
But what about all the dust getting on top of me?
Or do you mean to run the hose while I'm sanding?
classic33
Leg End Member
Run the hose out whilst you're sanding.
No one method is going to collect all the dust, but the hose running to where you're sanding works best at keeping it down.
Attaching the hose to the sander might mean an extra piece to buy, to allow it.
Electric_Andy
Heavy Metal Fan
Plymouth
If you're using a mains corded one, don't use a metal hose pipe or tube. I did that and got a nasty shock. Don't know if it was electric jumping out from the brushes, or a short somewhere. But plastic pipe only. May also have been static build up but it was a constant shock rather than a quick zap
