What to wear
Hi I have started using my bike to work again after the winter, the problem I have is what should I wear, I cycle early in the morning and late at night, and have a train journey in the middle of my commute. The past two weeks I'v ended up with the cold after each, because I think I cycle to wrapped up, is it best to start off your cycle feeling the cold then wrap up once you stop
BSRU
A Human Being
Swindon
A decent baselayer would help, I have Icebreaker 200 merino wool top and leggings, helps keep me warm in the cold and cool inside buildings.
Lots of layers that you can put on/take off where necessary (warm trains etc., but cold station platforms).
I only do a short commute at each end, and try to integrate items with my office clothes as much as possible, as we don't have much in the way of washing/changing facilities at work. Not much of my stuff is specifically cycle oriented other than the Hi-Vis
  1. Cotton vest base layer with integral bra (from Uniqlo, I have loads of these and they are back in stock for the spring now)
  2. Smart fitted black t-shirt and a-line mini/knee length wide skirt or black trousers
  3. If wearing a skirt, black opaques
  4. padded cycling 3/4 tights underneath the skirt or trousers (crazy London potholes)
  5. knee high leather boots with a rubber sole (pedals wreck heels). I keep smart shoes in the office under my desk, as well as a plain black suit jacket
  6. a velour zip up tracksuit top from M&S
  7. nice warm scarf
  8. Hi-Vis Altura Kinetic jacket (quite thin)
  9. If it is REALLY cold, I might pull out the Gore beanie under my helmet but I prefer to do that on the way home only as it gives me seriously flat hair (and I only have a pixie crop as it is).
I haven't had any more colds (fingers crossed) since before I started commuting in January (I had a very nasty flu over Christmas).
When I get on the train I undo the Hi-Vis, loosen or remove the scarf, and unzip the velour tracksuit top to let some air in.
There have been a few times I have felt cold but it wasn't when I was cycling, it was when I was waiting in between trains and Twickenham station is a bit of a wind tunnel.
I have found advice from elsewhere on the forum to slow down a bit at the end of the journey works really well to stop too much sweating - otherwise you don't sweat too much and then you stop and whoosh .....
fimm
Edinburgh
How far are your two cycle legs? I bike-train-bike on a Brompton wearing whatever I'll be wearing in the office (ie a suit or smart skirt/trousers + jacket) with a warm coat, scarf and gloves. The only thing I change is my shoes. But I dodn't cycle very far - the longer leg (at the office end) is only a couple of miles at most.
I'm on a Brompton too, and the only cycle specific things are the hi-vis/helmet and the shorts (and that is only because the potholes really hurt my underneath). Otherwise the top, skirt, opaque tights or trousers is exactly what I would wear in the office - we have a fairly liberal dress code but unless somewhere is very strict, I have found wearing black, black or black works really well .....
I don't bother wearing the smart jacket as I find it is too bulky underneath the hi-vis so I keep it in the office.
Sounds like the distances are much the same.
Moodyman
As above, but even dedicated cycle gear will retain some sweat which will cool when you stop and cause a chill.
Either pedal with less effort or carry spare tops for the train journey.
J
johnmillie
Thanks both halfs of my trip are about 3 miles with a 45 minute train trip in the middle, my early start Im on the train at 0545 and my late finish i get the train home at about 2100, I think ill try a diffrent route to the station from work as just now I cycle up a very step hill on the final leg of my commute, i chose this route originally to give a bigger challenge but might keep it till the summer.
400bhp
You don't get a cold from being cold (in isolation) by the way.
Get layered up-use cycle or running specific clothing as it is designed for the purpose.
corshamjim
Corsham
IME, the most important part of temperature control in winter is a windproof layer. Temperature control is by unzipping the front or undoing the cuffs of a windproof jacket. Don't forget to windproof your head too - a helmet cover helps as does a light hat under the helmet.
I normally wear ordinary office clothes with a windproof jacket over. Below 5 degrees I'll wear a fleece top too.
ymmv though - some people feel the cold a lot differently than others
J
johnmillie
Thanks for the help I went to my lbs instead if halfords today and the guy was brilliant, I got the proper lub instead of the spray I usually get advised to buy, a proper jacket and baselayer to wear under it, so I'm all set for work on monday now
