[QUOTE 2287282, member: 45"]New house again. 2 questions....
I want to fit an external security light. I understand I can take a feed from a socket, into a fused connection unit, and then out through the wall. Connection-wise, is it just a case of using the internal cable connections and screwing the feed to the fused unit into them?...[/quote]
On this question, my external security light is connected to a normal-looking double switch inside the porch ...one switch is for the porch light, the other is the switch to the security light (you can therefore choose to have the security light powered or not).It was fitted for us about a year ago by a qualified electrician. I can take the switch cover off and post a photo of it on here if you want.
