swee'pea99
A friend's CD player has gone awol, and I'm trying to fix it. I was trying to follow the instructions on this site, which says:
By now you will probably be able to see the CD tray (the bit that holds the disk) and also some kind of arm which hovers over the disk when the tray is closed. There will usually be a small motor for moving the lens over the disk, and attached to this or nearby there is typically a small circuit board.
On this board, or in any case rather close to the read head there can usually be found a small potentiometer (sometimes referred to as a pot). This will usually be a small square component with a plastic disk on top, and this disk will have a slot which is designed to take a small flat head screwdriver. This is what we will be adjusting.
Well, I'm damned if I can see anything like that. Any suggestions much appreciated...
