Which mini-pump?
Arch
Married to Night Train
Salford, UK
I've got a Topeak Road Morph pump that I carry in my pannier on the uprights, but it's just too long to fit in the Catrike's sidepods. I like the Road Morph, so I'm thinking of getting the mini version. Anyone got one, or got any other recommendations for trackpump type minis? Whatever I get needs to be shorter than 28cms.
And budget is 'the smaller the better'...
brokenbetty
London
I have one of these http://www.evanscycles.com/products/bontrager/air-support-mini-pump-ec017727 and really like it. It's tiny and pumps tyres pretty quickly.
Martok
Klingon on a bike
Watford
I liked the look of the Bontrager Air Support Mini Pump above. However, it was a bit bulkier than I wanted as I was after a mini pump that would fit in my Topeak Aero Wedge Large saddle bag. I then decided to get the Topeak Rocket Micro AL Pump which supposedly will inflate to 160psi.
Personally I'd recommend that you also pick up a CO2 pack. I also got the Bontrager CO2 Air Pack. You can then use this for any major tyre inflating and use the pump for any top-ups that are needed.
slowmotion
Quite dreadful
lost somewhere
Arch, I asked the same question a short while back, and loads of people piled in with advice......
https://www.cyclechat.net/
I went for a Lezyne Road Drive because I have had a load of grief with fixed head pumps and liked the idea of a flexible hose. It comes with a really nifty frame mount but is small enough to stash in a bag as well. It really works well. Yes, it probably costs a bit more than some others, and there are alternatives.
Good luck.
Arch
Arch
Salford, UK
http://www.cyclechat...e__hl__minipump
Good luck.
Ah, thanks for that, I knew I'd seen something recently, but didn't look hard enough.
I should have said, I'd also prefer a flexible hose, hence thinking about the Mini Morph. I find it hard to get a really good pressure with a normal pump, but the 'track-pump' style works well for me.
Arch
Arch
Salford, UK
I have a mini morph & it's ok. If you're on the Hull to York ride later this month, I'll let you play with my pump :blush:
I say! If I play with it enough, will the result be nice and hard?
Sorry, I'm still in work-double-entendre mode for some reason. ;)
GrumpyGregry
Here for rides.
+1 Lezyne Road Drive
A work of genius. An engineering marvel. An aesthetic delight, and a ruddy good pump too.
Tim Bennet.
Entirely Average Member
S of Kendal
Anything except one made by Blackburn.
It might just be me, but I've been let down by any number of different models from them.
But no more - I'll never buy another.
Arch
Arch
Salford, UK
Yeah, I saw that one, it looked smart.
Pricier though - it would be so nice for money to be no object, but...
I'll mither a bit longer...
redjedi
Brentford
I didn't say I got the full 140 psi into my tyres but I can get it hard enough :tongue: that I don't notice. Must be close to 100psi.
