Which Wheels?
Lizban
Having suffered (another) popped spoke, I've decided to bite the bullet and buy a new back wheel. Don't mind spending a reasonable amount (say£100-£150)
Any advice is my budget reasonable - clealry be happy if I could get a good wheel for less!
I cycle c100 miles a week on mainly roads and am a big unit (6 4 and 18 stone)
Any tips welcomed.
Cheers
potnoodle
Likes bikes and cars.
Bickley
I weigh in at about 17 stone and am 6-4 myself and kept breaking spokes all the time. I also had to bite the bullet and get a set of wheels made.
I went for a set of Mavik Open Pros on a Shamano 105 hub in the end. Cost a little over your budget at £200 but was what i was recommended by a number of people on this forum and other forums i go on.
Tim Bennet.
Entirely Average Member
S of Kendal
You should be able to get a single back wheel for that money.
But the advice above is spot on: You need a decent handmade wheel. Unfortunately just because someone uses their hands to build a wheel, doesn't make it a 'decent hand made wheel'. You need someone like Paul Hewitt http://www.hewittbikefitting.co.uk
L
Lizban
Thanks for the tips. If I am honest I really don't know what a good wheel is! I've looked at SPa and Evans and seen lists of wheels and other than price I don't know why one is better than the other!
dan_bo
How much does it cost to Oldham?
As well as that, I'd recommend a high flange hub laced to a deeper-section rim like a mavic CPX. the shorter the spokes the stiffer the wheel- I was popping spokes on my fixed gear for fun until I did that and I haven't had a problem for a year or so.
L
Lizban
What on earth does that mean high spoked big flange hubbed laced:blush:
dan_bo
It means a hub with a high flange and a deep section rim. Here's an example of a low-profile (ish) rim- this type of wheel would be used where stiffness is not the main priority, and here's a deep section rim, which, like for like, will build into a stiffer wheel. the flange bit is the diameter of the part of the hub where the spokes go into. the larger that is, the shorter the spokes have to be.
Crankarm
Nr Cambridge
I presume you're from Blackheath in London. If so go along to Condor in Grays Inn Road and get a hand built wheel on a Mavic Open Cd rim. They will sort out with you how many spokes you need 32, 36 or 40H and type. I would go for something like a Campag Chorus or Ultegra hub but number of holes will dictate which. My preference would be 32H Chorus or 36H Ultegra. You should easily get this for £150 or less. You might even be lucky that Monty himself builds your wheel, if of course he still does. He was last autumn, not retired yet.
HTH.
