gbb
- Peterborough
This should become the 'CycleChat Thrift Thread'.
Not wanting to pay a mere £24.50 for a C-spanner (flimsy stamped metal spanner-shaped object). I took a drill and file to the never-used headset spanner from my Lidl took kit. 20 minutes, and a lot of sweating later - I had my own C-spanner![]()
Surprising what you can turn out...
Cone spanners...just get a normal spanner and use a grinder with a sanding disc to reduce its thickness. I've brought very good quality spanners off the carboot for maybe 20p each, then reduced the thickness...infinately stronger than 99% of the dedicated stuff you'd buy.
Chain whip...length of mild steel bar, drilled in a couple of places to mount a used section of chain. Pretty it isnt, effective it definately is. Cost ?...virtually nothing
