Why are stems so expensive?
KneesUp
Eejit here has bought some handlebars off that auction site that are 31.8mm for a stem that is 25.4mm. So I've been looking at getting another stem, because apart from them not fitting, the bars I have are nice (by which I mean they were a decent price, they are in good condition and are in my possession) and I could perhaps do with a bit more rise in the stem anyway.
I've never bought a stem before; back in the days of quill stems you adapted to fit the bike rather than adapted to the bike, but I was expecting a generic unbranded stem to be about a tenner. After all it's just 10cm of aluminium tube with a couple of bolts. I thought that there would be some from China on an auction site that would be about a fiver. So imagine my surprise when it seems they start at about £25 if you want any rise.
So why are they so expensive?
mcshroom
Bionic Subsonic
No idea. Planet X can be good for cheap(er) stems though
http://www.planetx.co.uk/c/q/components/finishing-kit/stems?sort=price-asc
ASC1951
Yorkshire
... I've never bought a stem before; back in the days of quill stems you adapted to fit the bike rather than adapted to the bike, but I was expecting a generic unbranded stem to be about a tenner. After all it's just 10cm of aluminium tube with a couple of bolts. ..
I think there is your answer. An A-head stem - which I assume you are buying, and if not why not? - is a bit more than you describe. It's three pieces of decent quality metal, plus eight drillings and some fairly accurate machining. There is a lot more to it than to a stamped chainring, for instance, which you won't get new for a tenner.
Easytigers
I'm a little confused...I've never paid more than a tenner for a new stem. By looking through sales (or Planet X) you can get a wide variety of stems for about a tenner (usually with a 6 degree rise).
SteCenturion
I am your Father
You can quite easily pick up a Deda stem with a rise for around £15 - £20 posted & new from all the usual suspects.
Any cheaper than that & it is 'possible' you might end up with a stem fashioned from re-formed easter eggs & butter, disclaimer (might not be strictly true).
A stem to my mind is a pivotal part of 'the cockpit' of a bike bringing secure clamping & retaining stifness in the front end for your bars.
My favourite brand for all things stem, bar & seatpost is 3T with even their entry level stuff, named 'Pro' being very high quality.
I think if you were able to time travel to the days of Pro cyclists using quill stems & show them a modern bar & stem, they would have killed you to get it.
ASC1951
Yorkshire
Those are old stock or end of line and heavily discounted - although fine if they are in the length and rise that you want. But £9.99 for any of those stems will below cost price.
KneesUp
KneesUp
I just found it surprising. If you want to buy a derallieur, for example, you probably wouldn't spend less than £20 or so, but you can get a perfectly usable one for £8 at Decathlon. Ok it has no indexing and looks a bit basic, but it will change gear.
A stem is ostensibly a much simpler component requiring less precision in assembly, but the cheapest stem at Decathlon is £15.
I suppose it must come down to material cost?
