Winter bike query
graham bowers
@graham bowers what size frame are you looking at ?
down tube or sti levers ?
i always have a couple of retro bikes for sale in the 150 upwards price range
where are you based if local ish feel free to pop in and have a ride or two no pressure
thanks @Dogtrousers
56 Cm or thereabouts - not sure how different manufacturers sizing works.
I've never used down tube shifters so wouldn't discount them at this point.
I'm about an hour and a half away depending on traffic, Ashby de la Zouch area, so not really local. Thanks for your offer though, I'll get in touch if I'm over your way.
russ.will
Slimboy Fat
The Fen Edge
It's not the same as riding a motorbike, which adds heat into the corrosion equation and stones/crap/water hitting everything at much higher speeds and pressures.
I thought about a winter bike, but instead I've just fitted my RT-58 with Crud Catcher Road Racer Mk2 mudguards, resolved to wash it regularly, keep it well lubed and use the old motorcyclists favourite, Motorex 645 to protect the finish. I spray it everywhere and then give the rims/pads a quick Muck-off for obvious reasons.
Mind you, I've also decided that this years summer bike is next years winter bike...
Russell
biggs682
Northamptonshire
i have a few 54 & 56cm sized bikes at the moment
Mike!
Suffolk
New and a little more cash (£300) but the Triban 500SE looks good for a winter bike, looks like it has clearance and mounts for proper mudguards too if that's important
sidevalve
Decent quality bicycles seem much less susceptible to corrosion, partly cos they're better finished and partly because there's no heat to act as a catalyst.
Actually like m/cycles I find the chief reason for cheaper bikes corroding faster is a lack of care. The owner tends to think 'Oh it's just a cheap thing' and promptly forgets to clean / service /maintain it then wonders why it ends up looking like a rusty bucket and finally failing.
RichardB
Slightly retro
West Wales
I managed to get a Suzuki Bandit (Suzuki not known for their durability of finish) through two Welsh winters with almost no deterioration, even though the bike lived outside and was ridden daily on muddy and salty lanes. The method took half a day in the autumn and another half day in the spring, but with a bicycle it would be a lot quicker. Basically, I gave it a very thorough clean and then treated every surface (with the exception of seat, braking surfaces, controls and visible paintwork like the tank, which are easy to wash down anyway) with ACF50. This is a spray preservative developed for rustproofing airframes, and it's quite expensive, but a can would last several years for a cyclist. Think of WD-40 but much heavier and stickier. It's nasty stuff to apply, being a kind of sticky pink foam, but one application will last the winter. Once it's on, don't touch it. Hose down if needed, but no detergents. In the spring, use white spirit to clean the whole bike down, dismantling as necessary to reach the hidden bits. The bike emerges like a butterfly from a chrysalis and you are good to go for the summer.
Having said that, I will be riding through the winter and just cleaning and re-lubing as often as I can.
North West
+1 for ACF50 but not expensive at £15.00 a spray can. Just done my speed triple in it and one tin will last for next winter too. Good lubricant as well and washes off easy enough
North West
It was £11 a can when I last bought it. That's expensive compared to Wd-40, for example. Well, it is to me, but I am a terrible cheapskate.
No no your quite right compared to WD it is expensive. But what a product it is!!! I had a mate who ran a triumph tiger 955i through several winters and it looked better than some low mileage dry use only 12month old bikes.
Going to put it on my Genesis this winter and see how it protects it
