KneesUp
I have a wireless router at work, but it seems unable to cope with the devices connected to it. This peaks at 2 x laptops, 2 x phones and 4 x CCTV cameras but normally the laptops are connected via cable (along with 2 PCs, one of which only has access to the LAN, and a printer)
However, I'm finding recently that the wi-fi keeps cutting out and various devices are getting disconnected throughout the day. In addition the router rarely lists the wireless devices that are connected as being connected. I've changed the router (the ISP sent me several when I signed up - another story for another day) and it's behaving the same way. There are lots of other networks 'visible' and I've tried various different channels - I think the issue with that is the other networks are all set to 'auto' and so if I pick a static channel it becomes the 'wrong' channel as the others change in response to each other. However, if I leave it on 'auto' it is no better - perhaps as it keeps changing and some of the devices can't keep up?
I could really do with the connection being reliable. My question to you learned IT types is will a better router solve the issue - I guess it could be that the processor in the current router is overwhelmed or has a weak signal that gets swamped - and if so, which model would you recommend for my needs?
EDIT - this is the result of running a scan of the networks (nmcli d wifi) with the names removed. Ours is the one with 100% signal, although I was within 6 foot of the router. It's showing as channel 6 here but it had changed to 11 a few minutes later.
Cheers
Cheers
