Hi all,
As a relatively new cyclist was hoping you will be able to point me in the right direction! I've had a rigid mtb for a couple of years which has served me fine for the occasional journey on promenade rides. I've acquired a hardtail (?) as I'd like to do a bit more adventurous riding but this bike needs a couple of things doing to it. I don't want to spend a lot on getting it going so please be gentle with me
First off, I know it needs the bottom bracket sorting out. Currently it has the ball bearings enclosed in cage rings but one of the cages has corroded. Am I ok to replace this with a sealed cartridge type by (68mm housing, 122mm axle)?
And then I'm going to replace the chain to but my main reason for posting is advice on the chainring. I can't pedal the bike on the middle ring as the chain slips. It seems to be fine on the inner and outer rings so I assume that the rear cassette is ok and the problem lies either with the chain or chainring (or both). I've removed the crankset and see that there seems to be grooves inbetween some of the teeth which don't appear to be the same as the rest but, at the same time, there are four of these grooves spaced at approx 90 degrees and are where there is a lump on the face of the chainring.
In your opinions would you say this is worn or a feature of the middle ring? (I'll add a couple of pics in the morning as I'm typing this on my phone at moment and it won't let me reduce the image sizes)
Thanks in advance
Thanks in advance
