Worn rear cassette, and advice for replacement! ( Shimano )
stoatsngroats
South East
Can anyone tell me if this is worn..?
I intend to replace a worn chain, and thought I would change this too, but want to be certain that its knackered! ( I could keep this for spare!)
I'm replacing this one an with HG41 8 speed, and an HG40 chain. The cassette above is an HG 30, 8 speed, am I buying the wrong cassette!?
mjr
It depends what you want!
I think that cassette's largest cogs look pointy which usually means worn so I would recycle it.
I think that the shimano 8 speeds are pretty much interchangeable. I prefer KMC chains too, because I've never had one wear as fast as Shimano HG.
stoatsngroats
stoatsngroats
South East
It depends what you want!.
:laugh: Yep, maybe I wasn't asking what I wanted, rather whether it would fit!
:notworthy:
I'll go wth the Hg chain as it's ordered now, and I can cehck the wear as we go through the summer
I think that cassette's largest cogs look pointy which usually means worn so I would recycle it..
That's cool - thanks for your thoughts!
SnG
raleighnut
I think quite a few are showing 'peening' on the front edge (probably due to a worn chain transferring all the load to the front edge) only way to be sure is to see if they'll run OK with a new chain fitted.
stoatsngroats
stoatsngroats
South East
... unless the OP rides everywhere in a granny gear.
:okay: thanks for that! ^_^
Thanks for your thoughts, I think I will give it a close look, once the new one turns up! It did clean up well, better than i expected, and the chain was definitely trashed, so the new chain, and the new cassette will go on, and this one will become a spare foe a month or so.
Thanks again all! :cheers:
SnG
