Anyone got any experience of or views about XERT?
I've used it for a year... and just renewed... so I guess I like it. Podcasts are useful https://soundcloud.com/baronbiosys
whadda ya wanna know?
A few thoughts...
Hope all that helps!
- Took me a while to learn the ropes, very technical sounding, lots of jargon but the podcasts helped with that, there is a FB group too
- During the trial the workout pool is pretty limited, you will get more variance if you sign up
- You really need a power meter you can use indoors and out to track things (I use pedal based)
- Though you don't need to do FTP tests you still need to ride hard occasionally to keep your signature right
- The SMART workouts are something I find cool, it adapts to how you ride and will increase or decrease the length of intervals on the trainer
- The training pacer is good, it will take a couple of weeks to learn your routine, if you train hard and frequently it will start pushing up the workout difficulty to match your ability. I'm on 3* just now and find these challenging workouts
- If you do something a wee bit different from the program and decide to do a Zwift race or go for a segment outdoors it will adjust the workouts it recommends
- Once my fitness signature was dialed in I can use MPA to pace for certain efforts / races pretty well BUT...
- As mainly a TT event rider, for events over 10m I don't find MPA to be that much use as I am generally just at or below threshold power the entire time
- Also I personally find that what I can do power wise on a TT bike vs a Road Bike has enough variance to ideally warrant two signature profiles, which it doesn't support. As a result I can for example get a breakthrough on a climb outdoors but then when I do indoor workouts in TT position I can't meet the new power targets
- The advice it gives is generally good but at the end of the day you have control and though IMO better than a 'dumb' plan it won't replace a coach
