Need a replacement right arm crank spider, or chainset due to wear on the axle part of the crank.
So i'm after a 172.5mm 130pcd 105 Hollowtech or similar right crank (with axle attached) as you can't get this as a stand alone part i don't need chainrings, only the crank if anyone's got one.
