Based on what I sometimes do with the Bkool Classic, yes you can.This may be a silly question but can you use the Bkool Pro Turbo Trainer without (or even with power) power for using with cycling videos on youtube. Basically just as a normal turbo trainer. Does it have to be plugged in to use it?
Obviously, it can't adjust the resistance to simulate slopes but it still works as a basic turbo. If you plug in, you get some resistance. If you don't plug in, the resistance is minimal so you'll probably have to go up a few gears from your normal ratio to stop yourself spinning out. Good for pretending that you can ride fast
![Excited :hyper: :hyper:](/styles/default/xenforo/smls/hyper.gif)
