woodbine
- Bristol, UK
I have a 25 year old 18 speed MTB. It has original 6 cog Uniglide cassette and Deore derailleur. The 3 crank gears are original oval Biopace and shifters are Deore SIS. The bike was in storage for the last 20 years and I have re-commissioned it and started to ride it again. The old chain was very stretched and I have replaced it with a new KMC chain and also a new Uniglide hub. This is the chain I bought-
http://www.chainreactioncycles.com/kmc-x8-93-8-speed-chain/rp-prod25424
When I am pedalling in top/18th gear (ie. using both the outer cogs), occasionally the pedals slip forward slightly as if the chain has slipped on a couple (approx.) of teeth. This is accompanied with a clunk, then all is normal for a while and then it happens again. It's a bit disconcerting to be pedalling hard in top and all the sudden the pedals give slightly before retuning to normal.
I'm wondering if it's down to adjustment somewhere or some wear? I'm not sure if this would also happen still using the outer/smallest rear cog and one of the other two crank cogs - as I rarely use the 2 smaller crank cogs. Any advice would be much appreciated.
