Hello everybody,
I have an AMS - Cube AMS110
Gears/Shifters cables are routed inside the downtube.
They enter inside downtube somewhere near headtube an exit from it just before bottom bracket.
In the upper part, the cables tubes just stop into frame, in a tube end which is part of the frame.
In the lower part, there is a hole where an tube end is fitting (can be removed, the hole into frame is about 4-5 mm)
Now, trying to re-install the cables, I inserted the cable from upper parts (coming for shifter levers, naturally) into downtube frame, but there is no chance to hit the exit for the cable, even if the hole there is without the tube end (to be fit later). It seems there is no guidance inside the downtube and the cable is moving freely inside.
How do I pass the cables through the frame?
How do I exit the cable from the frame?
Thank you,
Puiu
Thank you,
Puiu
