[QUOTE 3936967, member: 9609"]I take it you're thinking of case hardening it with the old engine oil - would that improve springieness and memory ?
if I use a bit of hacksaw blade and bend it with heat, could I not heat treat that as you have suggested ?[/QUOTE]
Case hardening is a bit different, basically involving adding a very thin layer of carbon to the outer surface by heating then dipping in, well, carbon. Heating till red then dipping in oil, water or sand is fully hardening. The quenching medium controls how hard it will be - the quicker it's cooled, the harder and more brittle it will be. Brittle is not a good thing for a spring. Glass is hard and brittle.
After hardening it can be tempered, which will restore some toughness. Again involves heating but to a lower temperature than needed for hardening and the skill involved comes in getting the temperature just right - somewhere between the metal being straw to a dark blue colour. Thats the bit I usually get wrong when trying to get a decent point on metalworking chisels.
Cheap hacksaw blades will be all the same material but with the just the teeth cleverly hardened during manufacturing. I don't buy cheap hacksaw blades as they either seem to remove the teeth in the first few strokes or alternatively be so hard they shatter.
The spring? Just go buy one.
