hopless500
Trundling along
- not-as-flat-as-you-think Norfolk
We've had an open fire and now have a stove and never had puffs of smoke. However my paremts cottage smokes like a mad thing. Very small and bendy flue is apparently the cause.
Yes I think you're right, I've googled revolving anti down draught cowl and it's what I've got.We have always had an open fire. Although we don't light it all the time, I do recognise the symptoms you are describing there. Ours does it if the wind comes from a certain direction but only if it is above a certain strength. It either seems to go well (most of the time) but occasionally it is a bit of a dog. We have let it go out and put an extra jumper on.
Depending on your house layout a rapidly opened or closed door could also cause it to puff smoke.
I think the bit @Tail End Charlie is thinking of is a cowl.
Remember to turn the dog half way through its cooking!So I've cracked open a beer, let the dog curl up right in front of hearth and stopped worrying about it for the time being!
I'll see how it goes over the next few days but hopefully will be ok, and it was just me being paranoid. If it recurs though when the wind isn't high I'll consider getting the installer back.
Has the stack height been reduced? My mum had a problem with smoke coming back into the room after a bodger builder redid her open fire without checking that the chimney was the right height. Got someone else out who spotted the problem - mum's chimney was about 5 feet lower than others around, so he built it back up, and no problems since.
Have a look here for regs.
