ayceejay
- Rural Quebec
My carbon Guerciotti frame is in pristine condition but the transfers on it (white flashes and embellishments) let the side down. How can I remove them completely as any fix looks like a bodge.
Jetwash, just make sure you don't melt the frame.My carbon Guerciotti frame is in pristine condition but the transfers on it (white flashes and embellishments) let the side down. How can I remove them completely as any fix looks like a bodge.
If they have not been lacquered over, a hairdryer warm them up peel them of, clean of residue with WD40.
Fraid so, jetwash won't work either.Since the decals/transfers are lacquered/clear coated over it can't be done is the right answer
Most of the time.Are you off your meds raleighnut ?
I'd have posted the 1973 version of that song if it existed on youtube. (it's an obscure album track)Bloody Hell - Status Quo as an answer and 'reefer' is even older
Who mentioned sand blasting, I use a water jetwash to remove stuck on decals but as yours are under a Laquer/clearcoat that obviously can't work so the only way to remove them is to have the frame re-finished the same as you would have a Motorcycle (Carbon fibre) Helmet custom painted.Which is more extreme an obscure Status Quo track from 1973 or sand blasting my Geurciotti frame?
