montage said:
Ok....having a big bouncer is a must, but when I was out the other night I saw a hell of alot of HUUUUUUGE bouncers....I mean ones which struggle to fit their hands into those paper MacDonald bags.
I wouldn't fancy my chances against most bouncers, especially in the state one is usually in, but against these guys? You would run out of petrol trying to drive round them.
montage said:
Not bothered about fighting one... but the reeeeeeeeeeeeally fat ones just look as if they would come of second best every time :S :S
I don't understand where you're coming from.
You first state you wouldn't fancy your chances against most bouncers, which as a statement means you have given it thought and weighed up your chances. As I wrote, why are you even thinking along these lines?
Then you go on to state, "
but against these guys?"
If my understanding of the English language is correct, you are not wanting to fight some bouncers, but are weighing up the possibility of your improved chances against a fat one?
The use of the question mark (
?) led me to think, wrongly maybe, that your train of thought is that you are actually questioning the probability of coming out 'on top' having had a pop at a bouncer that's fat.
I then stick my oar in, and you then reply with pretty much an identical statement, albeit you don't actually state you fancy your chances against a fat one, you state they look like they will come off second best
EVERY time?
I'm sure before they pull on their trench coat and black gloves, they all search deep inside to see if they are 'up to the job'. That, I'm afraid is their risk assessment, not one that can be done vicariously by you.
