This running malarkey
rich p
ridiculous old lush
Brighton
Do it myself in 32 - 35 minutes.
Impressive - 32 mins for a 10k isn't far off national class.
rich p
ridiculous old lush
Brighton
Could never stand running clubs though.
10km
How old are you and where do you place in the all time Brit age group records?
40 Mike McLeod 29:13 Heaton 8.11.92
45 Martin Rees 30:17 Eastleigh 15.3.98
50 Tecwyn Davies 30:35 Reading 16.10.88
55 Martin Rees 32:02 Leeds 23.11.08
60 Martin Rees 32:48 Cardiff 8.9.13
65 William Marshall 36:01 Grangemouth 14.2.93
70 Stephen Charlton 37:55 Solihull 6.10.96
75 Stephen Charlton 40:36 Beckenham 6.5.02
80 Stephen Charlton 45:04 Newton 30.9.07
85 Gordon Porteous 54:09 Loch Inch 29.5.99
90 Gordon Porteous 67:02 Glasgow 22.10.04
classic33
Leg End Member
10km
Still two minutes slower than the age group above me.
PaulSecteur
No longer a Specialized fanboy
I used to use the elliptical as a warm up at the gym, thinking its almost a pedal stroke and low impact (I cant stand the gym bikes - bored witless in 30 seconds)
The gym then upgraded to a different type of elliptical, and I really don't get on with them, they have a much more round than elliptical stroke. So I tried the treadmill. I couldn't do 500 metres without knowing Im not doing myself any favours.
I could feel it in my knees (Im 100kg) and often had shin splints to various degrees.
I goggled running technique and found some useful advice, mainly about not heel striking.
I have gone from 500 metres nearly killing me to doing 5x 1000 metres, now doing 1k as a warm up and 2x 2k (at about 8km/h), totalling 5k in a session, in 2 weeks. The plan is to put them all together and do a treadmill 5k... then venture outside.
Might even see if I can find a local fun run.
Stephenite
Membå
OslO
I'll post the result on Sunday, don't hold your breath though, I'm 57 and have never run any where since primary school !
Good luck to you, MrP. I hadn't given much thought to your age. I am born a decade before you. I only hope it won't take a decade before i can run as far as you :smile:
I like running, but it is definitely harder on the body. It's better than biking in bad weather - you can go out, splash through the mud for an hour and that's it. I only do cross-country and fell running - can't see any attraction in pounding along pavements.
I too, fell-race, when I can, & try to only use the road-runs as distance/speed work
Sadly, I injured a heel in my last race, & have barely ran since that (November 16th)
That said, I've started again, & hopefully, should be on the start-line here; http://www.ilkleyharriers.org.uk/index.php?page=imr
Part time cyclist
Kent
I run and cycle depending on what stupid challenge I have set myself for the year!!!!! If i focus on running then the cycle fitness goes out the window and visa versa can't seem to get a happy medium where they both benefit each other ........
Dualthon?
When the weather improves I'll start cycling down to a nature reserve (a scenic 20k route) then do a 5k run there, followed by the circa 7k ride home. I generally just take off the cycling shoes and run barefoot (far too cold at moment) as its a nice grassy riverbank area.
