105 disc groupset 7000/5800 no longer available
Steve T
I bought this groupset from a friend earlier this week, but it turns out that the flat mount disc assembly is not easily compatible with the IS mounts I have on the bike I'm building so I need to get a post mount disc. I have discovered enough bits in the shed to get the bike built apart from the disc assembly so I have decided to sell.
I would also consider a part exchange with a post mount brake assembly
So the groupset is:-
R7000 172.5cm black chainset with a tiny bit of heel rub.
medium cage rear derailleur
front derailleur (bolt on type)
pair of 5800 STI with cables attached - it came off a 61cm frame so they should be very long.
pair of TRP spyres flat mount with good condition pads.
EDIT - I have a pair of black Tiagra rim brakes so if someone needs a rim brake groupset instead of cable disc I'm happy to sell those instead and the price would be £160 instead. I could throw in a brand new 11 speed SRAM 11-26 cassette ( too low a gear for me!) if needed too for £10.
He estimated this groupset had done no more than 750 miles from new.
I would like £200 posted or collection from near Wellingborough Northants for £190 (cable discs) or £160 ( rim brakes)
EDIT no interest on here so have decided to keep and get compatible disc brakes...
