What speed ?im sure ive seen one before but cannot find a 11-30 cassette for shimano fit. i can find 11-28 and 12-30 but no 11-30....
anyone?
10.... oopsy
its for brother in law, he has a 12-30 at the mo and just wants a bit more going downhillWhy do want a 30-11? Id say you only need a 30 in a very very hilly area and you have a standard 53-39 crank otherwise you can get by on a 27-11 maximum with a compact
would it be easier to look at the chainset then? I switched mine out from a 30/39/50 combination to 30/42/52 combination and downhill speed has improved (as has overall speed) but I still have that granny gear for the hills... just a random thought...its for brother in law, he has a 12-30 at the mo and just wants a bit more going downhill
It's not life or death.
He has a brand new 105 compact and the associated cost with swapping to a triple it's just not worth it.
The 11 tooth gives just a little extra and I personally prefer it.
We are not great climbers and only ride once or twice fortnightly hence the need for a 30.
True but running a 52-34 front is too far a gap to be realistically functional isn't it?you don't have to change to a triple - just increase the number of teeth on the larger of the 2 front rings. It will acheive the same result.
Avoiding the hills isn't really the idea behind cycling for me.What are you riding at the moment? Are you really struggling on the hills? Are there other routes that you could take?
