11sp Compatibility
aerobrain
Peterborough
Hi
Can anyone tell me how I can check if my hub/freewheel would be compatible with an SRAM 11sp cassette? I've currently got stock wheels on a Specialised Allez Elite with 2x10sp Shimano Tiagra.
Cheers
Lee
T.M.H.N.E.T
Northern Ireland
You'll need 11 speed wheels, 11 speed shifter set, chain and cassette.
You can however, ride 11spd wheels with 10spd cassette. Otherwise a lot of money for 1 gear.
aerobrain
aerobrain
Peterborough
So potentially the hub I currently have could be 11sp with a 10sp cassette, it's that bit I'm trying to establish. Is there anyway of confirming? The details I can find about the Aleez specs on the web don't give any detail on the hub. I did try looking for markings yesterday but couldn't see anything obvious. I'll try take a closer look tonight.
Handy to know that 11sp hubs are backwards compatible though as that way I can upgrade the wheels first then the drivetrain later.
cyberknight
+1
As TMHNET says you need an 11 speed wheel so you cant use a standard 10 speed wheel, chances are if your wheel came with the bike it will not work but if in doubt take it to a LBS and ask them.
Generally only Mavic hubs are already 11 speed compatible as they use a slightly wider freehub (and hence you use a spacer with a 10 speed cassette). Any shimano 10 speed have to be replaced with new 11 speed wheels.
aerobrain
aerobrain
Peterborough
But if a bought a wheelset from any manufacturer that is 11sp, can that still be used with a 10sp or is it only Mavic who have the spacer option?
Sorry if these are stupid questions, trying to get to grips with this cycling malarkey :-)
aerobrain
aerobrain
Peterborough
Cheers, now to start looking at wheels :-)
aerobrain
aerobrain
Peterborough
What else? I know I might want to change the tyres at the same time but else would I need? I assumed that I could just buy the wheelset (and shim) for now?! :-/
aerobrain
aerobrain
Peterborough
lol, I know that bit :-) I just wanted to find out first if I needed the new wheels as well, now I know I do I'll get them first then save up for the groupset.
Looking at the SRAM Force 22 so will take a few months to save me'thinks!!!
TheDoctor
Europe Endless
The TerrorVortex
You'd get far, far better value by getting some fast tyres, maybe a pair of handbuilt qheels and going on a training camp. IMHO fitting over a grand of upgrade to an £800 bike is madness.
