$50! What frame is this??
Fspeed
Washington State
Just got this on Craigslist for 50, seems solid I just don’t know what it is. I’m hoping someone can help me find some original photos of the frame and bike when it first came out?? Thanks!
Cycleops
Accra, Ghana
Difficult to say from those pics. We need close ups of the lugs, drop outs and any numbers on the BB.
Whatever it is for fifty noted you can't go wrong.
Fspeed
Fspeed
Washington State
Here’s a few more
Fspeed
Fspeed
Washington State
I think the numbers on the BB are GD912387
midlife
It has a brazed on kickstand bracket which usually means foreign frame or far east manufacture and imported. Loads of these ended up in catalogues like Grattens BITD. Unless you find a makers decal I'm not sure you will pin a name on it.
Fspeed
Fspeed
Washington State
where is the kickstand bracket? I can only find the little brake cable clips
Ian H
Ancient randonneur
I think I can see a kink in the down-tube, which would explain the non-matching fork.
Agreed, doesn't look British.
SkipdiverJohn
Deplorable Brexiteer
London
Could be anything, but looks like a converted multi-gear bike to me. The frame could even be half-decent. It's not modern, because it's lugged and it has a tubular rear brake bridge not a pressed flat steel plate often found on cheap frames. The diameter of the seatpost may also give you an idea if the frame is plain hi-tensile, cro-moly, or mang-moly tubing.
