Holdsworth
- Crewe, Cheshire
I have had my bullet cam that I bought from 7DayShop for a couple of weeks now, used less than 5 times since I've had it..
The thing that is bugging me is the charging light, it is supposed to slowly flash red when charging and then another light goes green when fully charged. Number one query is when the switch under the cap at the back is switched to the "off" position, no charging lights show at all, just the blue power light. The lights only come on when it is switched to the "on" position.
Number two; it takes ages to charge, first time was fine and it took a few hours but I left plugged into my PC at work all day and it was still flashing red, no sign of the green light after 5+ hours. It has sat plugged into my home PC since 6:30 and is still flashing after the commute home.
Number three; for some reason it failed to flash red normally at some points during the day, it was flashing red but in very quick succession, just blinking on and off. It should be a slow flash so I have no idea what was going on there.
I don't know if this is a sign of a knackered battery or not, there was one other report of such an incident in a thread on here.
A bugger if I have to return it as I didn't keep the box, Doh!
