8 Speed Bar End Shifters and Cantilevers
KneesUp
Hi - just wondering if anyone has a set of 8 speed bar ends and / or some cantilever brakes they could be persuaded to part with? I actually only need one pair of cantilevers, but I suppose it'd be pleasing if I had a matching set!
Cheers.
KneesUp
KneesUp
Yay - "won" some shifters on eBay at last. Still after some cantilever brakes if anyone has any?
Or has anyone any experience of Tektro CR520 - at £20 for a bike's worth I guess they must be good value? http://www.on-one.co.uk/i/q/BCTKCR5/tektro-cr-520-cantilever-brakeset-black
GrumpyGregry
Here for rides.
How old is the frame/fork you want to put these canti's on? The stud gap is critical and on older frames tends to be much narrower than current ones making fitting contemporary canti's a bit of a faff.
KneesUp
KneesUp
Thanks - didn't know that. It's a 90s frame, not sure on the exact date, but it had biopace on it so I reckon 92-ish?
GrumpyGregry
Here for rides.
I suggest you get a c-to-c measurement of the bosses/studs pronto. I've just been down this route on a late 80's/early 90's design tandem.
Mr Shimano does the mostly adaptable canti I came across the BR-CX50 (and more expensive sibling the CX70). Adaptablity chart can be found in this tech doc. and beyond the ranges given these can be set up for narrower studs with a little ingenuity.
Pottsy
SW London
I have Tekro CR720s on my Surly LHT. Very pleased with them so I'd recommend those. I'm not sure of the difference from 520 to 720s, they are a little more expensive.
dnrc
Norwich
i got a full set of cr720's here in silver with barely any use, coolstop pads on front.
£24 delivered
KneesUp
KneesUp
Thanks @dnrc but I live near Planet-x so I will probably pick up the 520's - they're not listed on the Tektro site anymore so I presume the 720 is some sort of upgrade, but they look the same to me!
GrumpyGregry
Here for rides.
Check that stud width before you part with beer tokens.
KneesUp
KneesUp
Will do - got my 8 speed bar ends today. Thought they only had 6 clicks at first but they'd just been put back together out of alignment after they'd been removed from whichever bike they were on - I'm getting there :smile:
