A rattle (sounds like it's coming from the front)
Dibs
West Lothian
Whenever I'm cycling along at a bit of pace, there seems to be a rattle coming from the front...
I've looked at the valve, seems ok. The nut at the bottom of the valve was a little loose, but I've tightened it up.
Any help with where I could look to work out what it is?
MontyVeda
exposed gear cable rattling on the frame?
Dibs
Dibs
West Lothian
I'm now thinking that sound is coming from front of the chain. Possibly the gear 'changer'? Will be checking it out...
Deleted member 23692
I had a similar noise.. and it was the outer gear cables knocking against each other
Dibs
Dibs
West Lothian
There is some movement in the front 'gear changer'. I presume this should be quite solid? I'm going to try to tighten it up tonight and see how it goes.
