Just a quick post to say thanks for all the advice given on my probing question how to relive the old problem of chafing. Have taken the advice and removed the gel seat cover and beefed up the old shorts.As for the seat problem on closer inspection i found that you were able to adjust it . So at the min all these things seemed to have helped. Going to commute to work tomorrow so twelve miles should soon tell if its helped. Tried to have a go last friday but had a small slip on greasey cycle path so as they say second time lucky or is it third .
