Advice choosing a factory built singlespeed
MoG
Notts
Hi folks,
As the title says, looking to choose the best sub £600 singlespeed, preferably one with a flip flop so I can try fixed once I have mastered the fine art of single speed.
My employer has just joined cyclescheme.co.uk and I want to take advantage of this as I will never have enough cash to buy outright (4 young daughters make sure of that!)
I like the bullhorn look, and have spotted the Plug 1 in Evans, the Mango range, and really really liked the Quella bikes (only to find out that cyclescheme is about the only ride to work scheme that they are not members of!!)
Any advice will be greatly appreciated, as I say any bike needs to be available on cyclescheme.
Evans do have my size Plug 1 2014 and 2015, I noticed that although the bike looks the same, some components have changed, does anyone know which is the better spec please?
Thanks loads
potsy
Rambler
My Armchair
This would be my choice and may still be yet when our C2W scheme starts again in the new year, £550.
Paul.G.
Just a bloke on a bike!
Reading
I looked at the Quella, some really nice looking bikes but in the end I've chopped up my Colnago Master and decided to make it into a single speed (too old for fixed) I've gone for bull horn bars rather than flat or drops.
Pottsy
SW London
A Colnago Master is a classic and normally stunning bike. Can I ask the age, what chopping up means and how can you make it single-speed but not fixed?
I'm just a bit horrified at the thought of such a frame with bull horns and an unusual build! Sorry, perhaps I'm just getting old :-)
Paul.G.
Reading
Its five years old, its the steel framed Master XLite. I had it built to my size etc, even down to hand built wheels and Campag throughout but I just got bored with road cycling and favour my cross bike on almost every ride, on and off road. So rather than it sit there looking all sad and lonely I thought why not turn it into a single speed and have some fun on it. I bought a single speed conversion kit from Charlie bike monger which simply slides over the freewheel. New chain and a single 39 teeth front chain ring. Short cross bike brake levers on the end of the bull horns, job done! Down side is all the bits are hidden by the Mrs as they are part of my Christmas presents so guess what I will be doing Christmas day evening!!
Paul.G.
Reading
Too old for fixed! What utter nonsense, I ride 6000 miles plus on fixed every year and I'm 55, there's plenty older than me on here as well!
Originally I wanted to go fixed but its very hilly round here which put me off the idea. I will see how I get on with the ss then I might get a new wheel built with a flip flop hub. How do you find hills on the fixie?
I'm a bit of a masochist,so i enjoy hill climbing,up to around %15-18, after that it's just too much like hard work,
Hilly in Reading?? surely not,mere pimples compared to cycling in the Pennines!
I ride on 46/17 for the hills, 46/14 for flattish routes
MoG
MoG
Notts
Thanks for your replies folks. Somehow feel none the wiser though !
The 2014 specs are,
The classic Charge Plug 1 2014 Singlespeed Bike: Simple, tough and reliable. Built around a clean, elegant frame and fitted with our award-winning saddle and grips. A true low maintenance bicycle.
Frame:
Cro-mo
Fork:
Steel
Number of Gears:
1
Chainset:
Shield track
Chainrings:
42T
Bottom Bracket:
Tange Seiki fully sealed
Cassette:
DNP 16t FW
Chain:
YBN S10CR
Pedals:
Wellgo alloy trekking
Brakeset:
Promax RC482
Handlebars:
Charge Slice
Stem:
Shield road, 31.8mm
Headset:
FSA TH-882
Grips:
Charge U-Bend 45
Rims:
Charge Urban doublewall
Front Hub:
Charge shield, fully sealed bearing
Rear Hub:
Charge shield, fully sealed bearing flip-flop
Front Tyre:
Charge Coaster, 32c tyres
Rear Tyre:
Saddle:
Charge Spoon
Seatpost:
Shield alloy
Seat Binder:
Single bolt
Weight:
Not Specified
the 2015 specs are,
Frame:
Charge steel Cro-mo D/T & C/S
Fork:
Charge Whisk Steel
Number of Gears:
Chainset:
Shield Track
Chainrings:
42T
Bottom Bracket:
FSA sealed
Cassette:
DNP 16t FW / 16t Fixed cog
Chain:
1/8 Shortlink
Pedals:
Wellgo Alloy trekking
Brakeset:
Promax RC482 Long reach
Brake Levers:
Pro-Max 239A
Handlebars:
Charge Slice
Stem:
Shield alloy
Headset:
FSA TH-882
Grips:
Charge U-Bend 45 degrees
Rims:
Shield 700c double wall 32h
Front Hub:
Charge Shield Cartridge bearing
Rear Hub:
Charge Shield Cartridge bearing Flip flop
Spokes:
14G Stainless
Front Tyre:
Charge Coaster 700×32c
Rear Tyre:
Saddle:
Charge Spoon
Seatpost:
Shield single bolt
Seat Binder:
Shield single bolt
Weight:
Not Specified
In your opinions, which specs are the best please?
TheDoctor
I've seen things you people wouldn't believe
Stevenage
More usually, the hills find me...
Seriously, it's a compromise. You need to gear low enough that you can get up the hills, but high enough that you don't unscrew your hips on the way down.
Paul.G.
Reading
I'm on the edge of the Chilterns just north of Reading so it is quite hilly but nothing like 15/18% as you've stated.
Paul.G.
Reading
The 2014 specs are,
Frame:
Cro-mo
Fork:
Steel
Number of Gears:
1
Chainset:
Shield track
Chainrings:
42T
Bottom Bracket:
Cassette:
DNP 16t FW
Chain:
YBN S10CR
Pedals:
Brakeset:
Promax RC482
Handlebars:
Charge Slice
Stem:
Shield road, 31.8mm
Headset:
FSA TH-882
Grips:
Charge U-Bend 45
Rims:
Front Hub:
Rear Hub:
Front Tyre:
Rear Tyre:
Saddle:
Charge Spoon
Seatpost:
Shield alloy
Seat Binder:
Single bolt
Weight:
Not Specified
the 2015 specs are,
Frame:
Fork:
Charge Whisk Steel
Number of Gears:
Chainset:
Shield Track
Chainrings:
42T
Bottom Bracket:
FSA sealed
Cassette:
Chain:
1/8 Shortlink
Pedals:
Brakeset:
Brake Levers:
Pro-Max 239A
Handlebars:
Charge Slice
Stem:
Shield alloy
Headset:
FSA TH-882
Grips:
Rims:
Front Hub:
Rear Hub:
Spokes:
14G Stainless
Front Tyre:
Rear Tyre:
Saddle:
Charge Spoon
Seatpost:
Shield single bolt
Seat Binder:
Shield single bolt
Weight:
Not Specified
I wish I could help but its my first toe-dip into the world of single/fixed gear hence my easy option of converting my Colnago. The Charge Plug does look lovely though!
ColinJ
Puzzle game developer
I think if I wanted a fixed/ss bike I would build my own since it would be a much simpler proposition than a geared bike. (Also - ready-built geared bikes seem cheap for what they are, whereas read-built fixed/ss bikes often seem expensive and/or heavy for what they are.)
